G
Guest
Guest
WHile making my denim pens(eaglemascus) I came across and idea that might be helpful.
I have read where some plug their tubes with a potato.
It might work but I can only imagine what the shop will smell like when I "Lose" the potato.I never remember to order beeswax plugging stuff when I place orders.
I do keep paraffin wax on hand for different tasks.
The problem with paraffin is it's too hard to just stick the tube in and then pull out winding up with a little "plug"
I tried scraping the tube across the surface of the wax,this filled the tube with wax shavings.
I then uesd back end of a rod that fit in the tube to "pack" the shavings.This compressed the shavings easily.
I found that I could push out this plug and repeat the process.After doing this a second time I put the first plug back in the other end and I had both ends sealed and was able to spread the glue everywhere(including on my fingers) but not get any in the tube.
The wax comes out easily and CA doesn't stick to it.
