This is a reply to Bill Baumbeck's comments about my (gripe) posting.
First, Bill, I don't mind keeping this at the level of a debate. But your comments edged uncomforatbly close to a personal attack. e.g. "..if you were paying attention..." I didn't like that and will explain why shortly.
The essence of your disagreement with my comments seems to be that you believe I either ignored the fact that softer platings wear fast(er) or am not capable of having learned that fact.
Some background on why I made the posting in the first place. The clip in question is on one of my very first pens, a European. It is less than a perfect turning job. I would find it unacceptable today. Until recently it sat in a drawer unused. Recently I changed the refill to red and use only two days month briefly for a particular task. As stated earlier it shows plating wear. The wear was rapid with very little handling or use. This is completely unacceptable and dissapointing.
I don't recall what plating it has, I believe it may be 10K as I ordered from CSUSA as one of their 'Create-Your-Own' pens, those are offered only in 10K.
However, with my initial kit orders, I was confused, possibly mislead by the CSUSA advertising copy. Like most people, I knew that higher karat gold jewelry is considered more desirable and luxurious. The explanation for 24K is twelve pages before the Euro CYO section. In part, it says in pure Madison Avenue advertising prose, "...share the same quality components found in our more expensive pens and are plated with 24K gold with epoxy topcoat TO INCREASE WEAR RESISTANCE." (emphasis added by me) A slick lawyer could probaly defend that. But to most beginners, who have not had the experience of dissapointment or advice from this forum, that sounds like a good thing. After all, they are saying the topcoat is there to INCREASE WEAR RESISTANCE.
So, I discount your statement of "It is no secret that any gold plating, other than gold titanium, are guaranteed to wear at some point in time." A beginner does not know that. And to many, it is, indeed a secret. My impression as a beginner was that 24K was the most desirable. I did not then know about the titanium platings.
Further, the comment I resent, "...if you were paying attention to the advertised platings on these components....". I don't like being talked down to like that. [
The fact is, my latest orders, including one with you, were placed before I noticed the wear problem on the pen in question. I might have rethought using theme clips anymore in the future.
You quoted a comment I made that "got my (your) hackles up." Then you quote it and say, "You are correct." Thanks, didn't mean to anger you with facts.
Actually, to be fair, I understand where you are coming from. What has happened here, I believe, is that experienced folks tend to forget the stumbling, learning process at the beginning. When I was teaching computer usage to beginners, I always kept in mind, "if they don't know, they don't know." Kinda obvious but easily forgotten. I have told beginners to use the mouse to move the cursor when they didn't know what a 'mouse' or 'cursor' was.
I believe CSUSA description are confusing and less than candid. Those on your web site are unequivocal. You tell it like it is. But visits to your site came after the fact, unfortunately.
Part of my problem with what I consider unacceptably rapid wear on these clips is that mass manufacturing and plating is so cheap. Similar jewelry findings can be purchased at a few dollars per gross by importers and often are resold at a few dollars per dozen.
As a former gunsmith, you, undoubtedly know that home or shop plating equipment can be purchased and the plating solutions are fairly reasonable. A small object, e.g. size of a mans ring, uses and infinitesimally small amount of precious metal. When it comes to mass production the cost is equally tiny. The importers can afford to buy and provide better quality products.
Your challenge in the last paragraph is interesting. I may, yet, find a product I can import and resell at a handsome profit. I have looked at several items: cap and ball blackpowder revolvers, wool blankets, Chinese herbal medicines and others. None really met my parameters of being able to resell without giving up the freedoms that have come with retirement.
Final thought on why there might not be a demand for these clips on higher end platings. Uh, they aren't offered. I do wonder why an item like the clips that are used for personalized 'special' pens aren't made with top quality materials.
