plastic vs acrylic ?
RonInSpringTX
Spring, TX.
ok just a question. Tonight I started turning some purple/black swirl "aquabright plastic" blanks from PSI for a cigar pen. It was listed on the last blanks page of the newest PSI catalog, but it is labeled different than the other "acrylester" or "mica/crushed pearl", or other acrylics & stuff. I noticed drilling the blanks & when I started turning them (about 2000 rpm w/gouge then with skew once rounded a little slower) anyway, I noticed the material works quite different. My wife thought I was melting part of the blank, but I assured her, the speed and the sharpness of my tools, no way!! I showed her the way the blank came from PSI, 2 sides very shiny & the 2 opposite sides dull. (kinda same way they looked after I took them down a little bit) I don't turn for minutes on end and I let piece/tools cool. (not that they feel even warm!) Do I stay with my same plan as with acrylics?? These really do feel more "rubbery" than the acrylic. What ya thinking?? Thanks in advance for your opinions & expertise!!
Ronnie
fiferb
Ninety Six, SC, USA.
Sounds like what CSUSA calls their celluloid. My suggestion is to keep on going. If you don't think your melting the blanks then you are probably right. I often get very long strings of material going down into the dust collector from this stuff and that is with a roughing gouge. Finish it like you do other plastics.
rherrell
Pilot Mountain, NC
I just have a comment. I've turned alot of plastic and have never stopped to let it cool. Try not stopping once, I really don't think it's necessary and it might speed things up a bit for you.:)
gerryr
Billings, MT, USA.
I suggest speeding up your lathe, 2000 rpm is really slow. I turn all my pens at 3650. And I agree with Rick, unless I have some other reason to stop I just keep turning until it's the diameter I want. I have never had any kind of plastic blank overheat while turning and if I did, I would re-sharpen my skew because that's the most likely cause.
