#PKMAJJRBTS—2-piece Barrel trimmer sleeve set
Jennings, FL
OK...so they are included in the Majestic Jr. kit I received...what are they for?
I read and re-read the instructions that came with the kit...downloaded them from their web page and did a search here.
Help?
Sean
LanceD
Houma, La, USA.
They are used as spacers for your pen mill to square up the ends of your blank. You will need a 10mm shaft on your mill to slide them on, then slip it into your blank to square the ends.
rizaydog
Wellsboro Pennsylvania
Yeah, the Majestic and Jr. come with them. If you don't get one with another kit, you can make them with a spare 7mm tube and a piece of wood. For what its worth...
