rincewind03060
I intend to make a pin chuck a la Don Ward's article "The Pentel Pencil Revisited". The one thing not covered in that article and others is whether the finished pin chuck should be heat treated (hardened) or not. Since the drill rod stock comes annealed, I wondered if it is hard enough to use as is.
Do you folk who have made pin chucks heat treat the chuck and/or the pin?
If so, do you temper them afterwards?
