Pimp Crystals - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 01-17-2019, 10:43 PM   #1 (permalink)
jttheclockman's Avatar
Photos: 104
Default Pimp Crystals
Ok I want to change a pimp crystal in a Majestic kit. I have read Johnathans tutorial about crushing on a drill press but am hesitant to try this for fear of scratching the clip. So I will pose the question out there, for those that have used kits that have the crystals in the clips, have you changed to something different and if so what method did you use and were you successful?? Another method I heard of is soaking in acetone but again afraid of damaging the plating. I tried prying out with a knife but that glue they use is strong and no success. Thanks for the replys.
__________________
John T.
My Photo Album
jttheclockman is offline   Reply With Quote Top
Old 01-18-2019, 05:42 AM   #2 (permalink)
More4dan's Avatar
Photos: 5
Acetone will remove paint but should not effect platings. Someone posted this week soaking the Deco clip in acetone to remove the crystal.
Iíve crushed one using a steel punch and a used dental pick to remove the pieces. Used acetone to clean out the glue. Iím thinking I should have just soaked it to start with.
More4dan is offline   Reply With Quote Top
Old 01-18-2019, 07:57 AM   #3 (permalink)
Photos: 1
Default
I used Jonathan's method and it worked just fine. I replaced it with a piece of wood to match the body, HRB, if I recall.
__________________
Tom
tdsmart is offline   Reply With Quote Top
Advertisement
Old 01-18-2019, 09:27 AM   #4 (permalink)
Herb G's Avatar
Photos: 18
Default
A Dremel tool with a diamond bit will get rid of them with the quickness.
__________________
Be happy in your work...Col. Saito
My lathes:
Floor Lathe
Bench top lathe
Herb G is offline   Reply With Quote Top
Old 01-18-2019, 01:18 PM   #5 (permalink)
Photos: 104
Default
Not quite sure my hand is steady enough for dremel tool surgery or crushing these. I may just try acetone and see what happens. If I ruin a clip so be it. Thanks everyone.
__________________
John T.
My Photo Album
Old 01-18-2019, 01:27 PM   #6 (permalink)
skiprat's Avatar
Photos: 227
Default
John, how about a heat gun to release the glue?
Can you get to the back of the stone? Maybe press it out with your drill press and the clip stone over a small hole in a piece of mdf or something?
__________________
www.skiprat-pens.com
skiprat is offline   Reply With Quote Top
Old 01-18-2019, 01:44 PM   #7 (permalink)
Photos: 104
Default
Yes maybe will try heat first if I do not discolor plating.
__________________
John T.
My Photo Album
Old 01-18-2019, 03:16 PM   #8 (permalink)
JohnU's Avatar
Photos: 2
Default
It's been a while but I did one in the past prying it off with the corner tip of a razor blade. Good luck!
JohnU is offline   Reply With Quote Top
Old 01-21-2019, 12:41 AM   #9 (permalink)
Photos: 104
Default
Quote:
I like the GOOD LUCK part at the end John I will first try the prying, then heat, then acetone. Then dynamite
__________________
John T.
My Photo Album
Old 01-21-2019, 09:47 AM   #10 (permalink)
Chasboy1's Avatar
Photos: 0
Default
Newbie here! What’s a pimp crystal?
Chasboy1 is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
