Pilot G2 Comparison to Schmidt 888 Rollerball
Dick Mahany
Palm Springs, CA
I have been searching many threads here on whether a Pilot G2 Gel rollerball can be used in a pen which would normally use the Schmidt 888/5888 refill. As many have found out, it does fit, however there is a subtle mechanical difference that may matter to some. The Pilot G2 extends beyond the tip of the nib by 0.020" less than the Schmidt. The pen I used was a Jr Gent II from CSUSA. It's a seemingly small difference, but is noticeable.
I documented the two sided by side and posted the pics in case it would be of interest to anyone contemplating the same situation.
Did you like how the G2 wrote? When I tried it I thought the G2 was not as smooth as the schmidt.
I'm not very experienced with rollerballs and couldn't really feel any difference. I wanted to try the Pilot refills since they don't need to be capped and may open up other possibilities.
People like what they like. Some people are in love with the g2. I like it too but not necessarily more.
I usually tell people that it will accept the g2 if they prefer.
The tip exposure doesn't bother me any.
Good to know!
One reason to get Pilot G2 is finest 0.38mm model which is much thinner then 888/5888 Fine (0.6mm). And I'm asked about it sometimes.
G2 is also washable which makes them very bad.
What do you mean Ed? The ink can be removed from something with soap and water ?
When you say very bad you mean on checks / important documents?
I have personally seen several victims of check washing that used g2 ink. Also ammonia, detergent, rubbing alcohol and vinegar will remove the ink.
Washing Checks This is what I was referring to.
I had 2 clients in the past year that was victims. One $2.xx check was washed to $2,xxx and the other was a payroll check, it was duplicated but not washed.
I have used the G2 as well as the uniball signo inks in mine. they work just fine. the color options and ink matching to other people is important
Uni-Ball Signo 207 is a much better choice it is check safe,length is a tiny bit bigger than G2, 207 has a much better nib end for the spring if i had to pick one the Uni-ball wins hands down for me.
I guess that's why I don't write personal checks anymore and do my banking electronically with Credit Union generated checks if needed, but most of my vendors take electronic transfers. They mess up, they are responsible and my accounts are fully secure to my liking.
While on this thread I have often wondered why there is no ink testing on IAP. If you head over the fountain pen network they have a dedicated section just for ink testing.
There are two VERY BIG differences between the G2 and the 5888.
Thing one: Pilot G2 with gel ink is "permanent and waterproof" ink. This is easy to prove to yourself in the shop. First, take two checks, write one to yourself with a 5888 refill. Write one to yourself with a G2 Gel. THEN Take a QTip soaked in acetone and rub over the writing on both checks. The writing from the 5888 will disappear. The writing from the G2 stays put. next write on a piece of bond paper with both the G2 and the 5888-THEN, wet the paper. The 5888 runs, the G2 doesn't. Finally write a quick word with both, Then try to smear the ink. The gel ink is much more smudge resistant. this seems to be very important to some of my left handed customers. FWIW, WE HAVE NOTICED GREAT differences sins drying times between and and medium point of the 5888.
Thing Two: try writing through a four part (or even a three part) NCR carbon less form. The back copies written with the G2 are much more legible.
I, personally, LOVE the Schmidt 5888 (particularly the medium blue) and it's my favorite. BUT, I sell just as many G2 refills. The people who use them, LOVE THEM.
FROM A PEN-SELLING POINT OF VIEW, I could care LESS which refills the customer prefers. MY JOB is to make sure that said customer knows my pens leave ink preference to them. Many other pens CAN'T use both.
Respectfully submitted
Does anyone know the model no. for the G-2 refill that replaces the Schmidt refills? A while ago, I looked for them at Staples and had trouble finding the right one. I have a friend, who is also a customer, and he wants me to make him a pen with a G-2 refill. Thanks.. Larry
Staples had a recent sale on 5 packs of G2 plastic pens w/refills for $5. The individual refills were $2.99 for two. So I just got the 5 packs and removed / salvaged the springs and cartridges for = $1 each.
