jeff3285
can anyone tell the differences between pens plus finish and shellawax,,and what they actually prefer,,thank you
Where can you purchase pens plus? Thanks Jeff
Have you tried PP, instead of BLO, with CA?
Dan -- I have been using walnut oil with CA with no problems. Dutch Chemist (PhD kind) described the action between oils and ca as forming a polymer. CA is very reactive. Walnut oil is has lower viscosity and applies easier -- and is less amber. Lower risk of fire from spontaneous combustion. Try it -- you may find it works for you too.
But you wouldn't use pens plus with the wax right?
Dan, I am going to play with CA and Pens Plus - I went back and did some reading of Russ Fairfield's writings. Russ liked to sand with paste wax and was not concerned about it when it came time for finishing. Russ claimed that most of the wax was wiped off, and if of concern, a fast wipe with mineral spirits washed away the remainder. I suspect that most of the wax wipes off in the application and most of what remains is a walnut oil and shellac mixture. I have used CA over shellac with good success. Will head to WoodCraft next week and get a fresh bottle of PP and some fresh CA and play with some Narra wood. My guess is that one can put CA over PP without a peeling of the CA.
Does the Pens Plus finish last on pens for a very long time or does it wear off like shella wax?
I have never tried PP, I am happy so far with CA, but open minded. My question is what advantage does PP have over a CA finish other than ease of application? Does it last and long and remain as shiny as CA while supplying an equal or greater level of protection?
Vince, Do you use the PP as the final finish or are you saying you put CA over the PP? I am still trying to find someone who can say if the PP finish lasts and looks as good as the CA. I am not a big fan of the CA fumes.
