Pen tubes
jimmyz
Providence Forge VA
Can someone tell me if the tubes for the Navigator and Jr. Gentleman
are supposed to be the same diameter and length? I tried to compare them with what I had in stock, but the smaller diameter tubes in each set seemed a little different. Thanks.
Did you look in the chart in the library of all the kits??
magpens
Canada
The name Navigator may apply to more than one kit (from different vendors). . The name Jr. Gent is pretty universal.
I have a Navigator kit (from Woodcraft ?) which has tubes the same size as the Baron. . These tubes are considerably smaller in diameter than the Jr. Gent tubes.
As John said, you should consult the tables referenced on the Home Page of this website. . There are different tables for each vendor.
Having said that, I hope my info helps you find what you need to know.
You many not find the Navigator in those tables. . I looked some time ago and can't remember if I found "Navigator", but Baron is there for sure, as is Jr. Gent. . I think I found both of them under the vendor name Berea and also under ExoticBlanks. . Hope that helps.
