Hi,
I have been using brass tubes that come in the kits since I started. I find however that sometimes the material can get damaged on the insides when I squaring the ends. This has caused some instances of the pen not twisting easily as the refill catches on the insides of the tube.
I use the barrel trimming system as sometimes my wood blanks are not square so using the lathe trimming bit would not work.
I see some other tubes made of nickel and enamel.
Any experience with these? Are they any better and worth the expense?
Steve
Steve
