Pen Press
maxwell_smart007
Lead Moderator
Staff member
middle of nowhere in the great, white North
I guess I need a pen press, but I have no idea which one to order. Are they all the same, or is one better than the others...
I've looked at PSI, CSUSA, Lee Valley, and Woodcraft - they all look similar, but the Lee Valley one is more expensive (and unfortunately teh only local option - but I can get one shipped if I have to!)
Andrew
potter
Germany.
Hi Andrew,
i made a press myself. I had an old drillmachineholder ( sorry, dont know the correct english word)and turned two pieces of POM (plastic).The clamp (?)of the machineholder was too big, so i glued the POM into a piece of wood.
I am happy, this tool works fine, and i hope you did understand me...
greetings Harry
IPD_Mrs
Zionsville, Indiana
If you are patient one of the members on here makes a killer pen press. Check with Paul in OK PHDesigns. You may have to wait 6 months but from what I am told it is well worth it. I think I still have three more months to wait for mine. [:p]
OKLAHOMAN
Costa Rica
Originally posted by MLKWoodWorking
<br />If you are patient one of the members on here makes a killer pen press. Check with Paul in OK PHDesigns. You may have to wait 6 months but from what I am told it is well worth it. I think I still have three more months to wait for mine. [:p]
Here is a picture of Pauls press, well worth the wait.
Dave_M
Clovis, CA, USA.
I thought this was a pretty good home brew press: http://www.penturners.org/forum/topic.asp?TOPIC_ID=28285&SearchTerms=pen+press
Pomona, California, USA.
I have, and occasionally use, a press from CSUSA, but more often I use an arbor press from Harbor Freight. Works great, and some folks here have made turrets for their HF press to accomodate a number of different pen types. Only precaution: be cautious in its use--it can generate a LOT of force!
CaptG
Otsego, Mi, USA.
Andrew, forget the Lee
valley press, it has the same weak link design as the other three. About an hour ago I was pressing togather a blue lapis blank that took all morning to slowly drill and turn and polish to mirror like finish, with a gold and rhodium Majestic fountain pen kit (with one of Anthony's 14K nibs) when the press ram supports bent and the ram angled up and in that split second I heard the fatal "crack" and scratch one blank. No spares on hand, the replacement blanks are on the way but now the customer will have to wait a few more days. I flattened the offending press with my 20 ton hydrolic press so I would not try and "fix" it later. [:(!] Stay away from these presses.
karlkuehn
Banned
Lancaster, Pennsylvania, USA.
Sheesh. I've been using an Irwin ratcheting 6" hand clamp for the last three hundred pens or so. Works just fine, and after the first dozen pens, the holes in the little yellow rubber 'mar guards' on the clamp jaws are all set the way I like. All of the various nib holes that get 'cookie-cuttered' into the one side all correspond to the matching pen transmission/threaded fittings holes on the other side. I just have to remember which set of holes goes with what kit. Speaking of which, I should probably label the rubber pieces on the clamp with a sharpie! Probably save me some time when I'm assembling and wondering which holes to use on a particular kit.
These clamps can be grabbed 4 for $20 (regular price, sometimes even on sale) from most Home Depots and Lowe's-es, and I'm still on my first one. Any pen assembly that requires more force than what these clamps can produce is a good candidate for splitting out, and I ream the insides of the brass tubes accordingly to make sure I have a snug, but not too tight fit that will warp the shape of the tube. When you have to squeeze so hard the that clamp starts to groan, the fit is just plain too tight, IMHO. [:)]
IPD_Mrs
Zionsville, Indiana
Originally posted by OKLAHOMAN
<br />
Roy that was just wrong to tease us like that![}:)]
wdcav1952
Activities Manager Emeritus
Originally posted by karlkuehn
<br />I say Cav, I get the distinct feeling that you were just 'zinged'! [:p]
ZINGED?!?!?! I would say the gnarly knave skewered me!! [;)] First my beloved Tigers cough up a hairball at Kentucky and now this!!!!!
Good shot, Mike. To mangle Shakespeare, "beware the ides of October!" [}:)][;)][:D][:D]
karlkuehn
Banned
Originally posted by wdcav1952
<br />
Tigers? Wow, they still have a team? Huh...well, I don't much follow the high school circuit anymore. Muha![}:)]
Sorry, I figured since taking pot shots at Cav seems to be the IAP thing to do, I'd give one a try. Gotta say, it is sorta fun! heh [:D]
wdcav1952
<br />
<br />
Jeff, do they make cyber-helmets???? I need one quickly. [:D][:D]
Randy_
Dallas suburb, Texas, USA.
I used to use my drill press. Bought a 1/2" hex head bolt and epoxied a hardwood scrap to it and chucked it in the DP. You don't even need to do that, though. You can take a scrap piece of hardwood and turn it round on your lathe so it will fit in your drill chuck.
Changing the "ram" in and out of the DP got to be an annoyance so I built my own press. You can see pictures of it in my photo gallery.
wdcav1952
<br />What is even worse Cav it's even a fellow PA. Maybe you should offer him a free dental check-up!
Great idea, Mike!! [:D]
Hey Karl, run out and do a federal crime and I will do all your dental work for free!!!!!!!!!!!!!! [}:)][}:)][}:)]
karlkuehn
Banned
<br />
Hey, there's a neighbor that's got a big old burl about halfway up one of his trees. Is stealing trees a felony? I could use a filling or two...[:p]
ahoiberg
Ames, IA, USA.
this thread has a million good ideas and everything you ever wanted to know about pen presses but were afraid to ask:
http://www.penturners.org/forum/topic.asp?TOPIC_ID=22916&SearchTerms=pen,press,harbor,freight
