This is a PERSONAL post. I wanted to see if I could give some definition to the wearing of the finish on the pen parts in various kits. In no way is this test or the results to be interpreted as coming from the IAP or being validated by the IAP.
My set up is very similar to one that the is used by furniture manufacturers to test fabric samples. I set up a 1/3 HP motor to an oscillator that moved a rubber plate back and forth 3 inches. I attached a small piece of corduroy to the plate. I then mounted various pens parts...caps, centerbands and clips...to a block of wood with 5 minute epoxy.
I then ran the motor at a fairly low speed (500 RPM), timed to approximate the number of brushes against the part. I then tested the parts from various manufacturers. I will not report on the results by plating type and NOT by manufacturer as there would need to be a more rigid structure to testing one manufacturer against another. Let it suffice to say that I used parts from all 3 major manufacturers.
Results
24kt gold plating - Some visible wear at 3-5,000 brushes
Upgrade gold/epoxy gold - Some wear at 5-10,000 brushes
Silver - Some wear at 15-20,000 brushes
10kt gold - some wear at 15,000-20,000 brushes
Chrome, platinum, rhodium, titanium - No noticeable wear at 20,000 brushes
Rose gold - Not tested
These results are from a single test. I haven't subjected them to independent verification. I don't claim that they are accurate, but only the results that I obtained. Use the information at your own discretion and risk.
Results
