mbower
Since I started turning, most of the time I've used a pen mill. But I'm beginning to wonder if truing up is better done with sanding. I've seen the device from PSI to put on a disc sander and it seems to me (newby here) that sanding to true would be gentler on the end of the blank than a pen mill. Pen milling just seems so rough on the end.
I'm not talking about specifics. This isn't a question about my technique with a pen mill. It just seems that that cutter whirling on the end of the blank is hard on the blank. I have had a couple of blanks ruined by the cutter and I'm sure that was my fault.
So I'm thinking about getting a disc sander and either buying the PSI device or making one similar.
I'd like you folk's comments.
