GABJR
any suggestions on cleaning & sharpening pen mills
Originally posted by cozee
<br />What does Paul charge as new cutters from Woodturnings is a little over $10.
I know there are cutters out there for cheap. I feel that these are also cheap steel. They will work, but the 'factory' sharpening job is not always the best.Originally posted by cozee
How do you know the hole is dead square with the end?Originally posted by bmchan
<br />Rather than use the mill, I prefer to put a square CMS cut on one end and insert the tube flush with that squared end. After the glue dries, I use the CMS to sneak up on the tube. I then use a belt sander to complete the squaring. You have to learn how to slice a rec C-hair with ease.
Originally posted by Paul in OKC
<br />I know there are cutters out there for cheap. I feel that these are also cheap steel. They will work, but the 'factory' sharpening job is not always the best.Originally posted by cozee
For one mill, you may decide to buy one. My price is $10 for one, $5 for each additional one, so the more you have the better the price!
