PhilSmith
I've recently gotten into pen turning and have purchased (among other things) a pen mill set.
The mill set I purchased supposedly has 7mm, 8mm, 3/8in, and 10mm cutters. I've found that the 7mm and 8mm cutters are of "expected" size, but the 3/8in. and 10mm cutters appear to be the same size. That is they're both 8.63mm or 0.34in in diameter. (Based on an inquiry, the company I purchased from sent me a second set for comparison. And the second set is sized the same as the first.)
The 3/8" brass tubes I have on hand have an OD of 0.368 or 9.36mm and an ID of 0.354 or 8.99mm.
Can anyone tell me the OD/ID of 10mm tubes? Are they any different from the 3/8"ers? And should the 3/8" and 10mm cutters be of different sizes.
Thanks....
Phil
Thanks....
Phil
