Can someone please clairify when to use a pen mill sleeve as opposed to just using the cutting shaft? Are sleeves used for blanks that do not accommodate the sizes of the cutting shafts? (the long portion inserted into the tube and attached to the cutting head). If so, how is any adhesive cleaned from inside the tube? I'm confusing the issue here and would appreciate some clarification.
