Dario
I have the pen mill set but there is no mill insert that will properly fit the Baron tubes...what do you use or did?
I am planning on turning/making an adapter...probably using a 7mm tube and turn one that will match the ID of the baron tubes. Any recommendation on what wood to use?
Or is there better ideas?
