Pen Material?
We all make pens from acrylic, wood and sometimes metal and sometimes a combination. I also know some people use clays. My question does anyone make pens using other materials? I am not talking embeding with clear resin. I am talking about materials such as leather, braidings of some sort, cloth of some sort or other materials. If so do you have any photos and can you give us a little background as to what it is and how well does it play out there? If you do use something, are you using a kit pen to aply to and if so what kit?
Ian Thorn
Mosgiel New Zealand
I have made a few lattly useing deer antler from near the tips to get both bone and hair as a contrast it needs sanding to at lest 1200 then ca to seal the hair part before polishing.
Cheers Ian
PenPal
Canberra, A.C.T., Australia.
John T
I have made pens from a multitude of materials, this pen was made from a stripped, modified Dental Handpiece gutted, reworked inside fitted with a Slimline brasses and winder as a working pen. The metals include stainless and brass multi threads, removal of air and water tubes etc, the timber is Hairy Oak cut at 90 degrees across as part of a pen rest and set for a mate. Pics show detail outside using exposures to show the detail of the metal and timber.
Using three brass knurled Darts a composite pen was made fitted to a score book also using Slimline parts to enable a twist mech and easy to replace the biro using two brasses.
White Corian and African Ebony Slimline bits.
Handpainted, drilled , faced Beads.
Old pics bad luck changed computers a while ago so pics only to give ideas.
Have fun I do.
Kind regards Peter.
PenPal
Some more pics. My Spark Plug pen African Ebony white Corian, Straight Air Gun Modified Slimline Streamline can be operated by the knurled section or the top.
Cheers Peter.
flyitfast
San Antonio, TX 78247
its_virgil
Wichita Falls, TX, USA.
You're welcome Gordon. The .pdf file was originally a power point presentation I used for a symposium demo on "Alternative Materials". Most, if not all, of the en pictures were submitted by IAP members.
Do a good turn Ailey!
Don
Don, thanks for pointing this reference out. And, thanks for putting this tutorial together. I found several things I want to try.
gordon
Don
Excellent post. Basically I wanted to show some of the Newbies that there are other materials to use and other ways to make a pen. To explore and expand the basics. That is a good starting point and well put together. Hopefully as time goes by this can be expanded even more. Thanks for posting.:good:
