JimGo
I'm in the process of making some pen boxes, and I'm trying to make the boxes the appropriate size for the pens that will be housed in them. I have a bunch of unopened kits at home, and since I've never turned pens for them, I don't know what the final dimensions will be. If you have any of the following, would you be kind enough to add the finished dimensions for a "standard" pen to this list:
Length Largest Diameter
Slimline:
Cigar: 7 5/8" 5/8"
Baron:
Jr. Gent:
Series 2000:
El Grande:
Ligero:
Obviously, I don't need exact measurements; I need enough room to make everything fit comfortably. For the diameter, I was measuring with the pen on a flat surface, and looking at the highest point away from that surface (which I think in most cases is the clip).
I'll fill in the Slimline later, when I can get home to measure it, but any help with the other kits would be appreciated! Also, if you want to turn this into a more comprehensive resource, please feel free to add other kits too!
Slimline:
Cigar: 7 5/8" 5/8"
Baron:
Jr. Gent:
Series 2000:
El Grande:
Ligero:
