After you install the tranny and you go to put the top part of the pen on ( I am talking slimlines) and everything goes together well. You go to turn the top to expose the ink refill and it comes out as expected. Now if you continue to twist the cap it will continue to spin in the tube. Is this normal???? There is a slight stop position but you can continue to turn the cap. Go to retract and everything is well but you can again continue to turn the cap. If this is normal is there a potential problem down the road of the tube stripping out. ????
