PenMan1
Two points I want to make about drilling on the lathe vs drill press.
1. With a drill press I can drill a single resin blank section in less than one minute, wood blanks are a little faster. That includes everything from bit touching blank on one section until bit touches blank on the next section; loading, unloading, putting down one and picking up another. I leave the drill running when I change blanks. With the lathe I need 4 1/2 minutes to do the same thing. I think I could save a minute or more with the PSI dedicated chuck. I use the drill press because it is much faster.
2. Why does the hole need to be in the center of the blank anyway? I know in some segmented blanks it is needed, but with most blanks I drill wherever the coloring or grain looks most interesting, not in the center. I can't drill off center with the lathe, actually it can be done and I do it with antler, but that is a still slower technique.
Man! It is obvious that the two of us are on the same page!!!!!
I DO drill the midline and upper end pens on the lathe. IT IS more accurate, period. BUT, as you point out it is SLOW as Hell!
I take every time savings shortcut that I can and still maintain as much accuracy as possible. On lathe drilling, I KEEP 6 Jacobs chucks loaded with my most common bits. THIS TAKES 1 MINUTE PER PEN out of the my drill time! Doing what we do, THAT's HUGE!
Someone here, once stated that "turning between centers" takes 17 seconds longer! My wife nearly PEE'd herself laughing! (Here, Razors go on a "special" drill rod mandrel, 3 at the time!) 17 SECONDS, NOW THAT's FUNNY!
The concept of taking a 10" 7mm tube and gluing three "razor" blanks at the time would be lost, here, too.
I suspect people using scroll chucks ARE NOT making the volume of pens that the two of us are are making (I "kinda know" your numbers), since we "talked" last, my production numbers this year are about 200 pens "north" of where yours were last year.
On the 7mm units I produce, (razors, stylus pens) and single barrel pens that I make, I DRILL ON THE DRILL PRESS. Granted, I have a decent press "tweaked" pretty nicely with a Huffman press, BUT on the small stuff, you are EXACTLY RIGHT! unless it's segmented, checkerboard, etc, WHAT DOES IT MATTER if the hole is down the middle? "There is plenty of meat"! AND YES, "I keep the motor running", too
Snickering.....Because you cheat:biggrin: ( Wife goes one way, you go another), To try to make and SELL 3,000 pens per year, THAT MEANS after you subtract AT LEAST 2 days out of each week to actually GO SELL THE PENS, you MUST AVERAGE MAKING 12 PENS PER DAY (15, If you want a week of vacation).
I think ours is a different world for many here.
Respectfully submitted.
