Pen Blank Drilling Chuck - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 11-15-2018, 10:18 AM   #1 (permalink)
Photos: 7
Default Pen Blank Drilling Chuck
Hello! First post here and a new turner as well. I donít have a drill press yet so I am using a dedicated drill chuck on my lathe and Iím not that impressed so far. The drill bit (Fisch) seems to wobble when it gets to the blank and the opening at the end of the blank could be 1/8 bigger than the other end. Am I doing something wrong? Any tips or better way to do this? Thanks!
Sent from my iPhone using Tapatalk
TurnKC is offline   Reply With Quote Top
Old 11-15-2018, 11:07 AM   #2 (permalink)
Photos: 12
Default
Your setup is unclear to me, is the drill bit spinning or the blank?
I use a 4-jaw chuck to hold the blank at the headstock (so the blank spins). I have never heard of anyone doing it the other way around, though I suppose it is possible. If using a chuck to hold the blank it is critical that the blank is mounted parallel to the bit. One way to help get this right is to turn the blank round first, "pen jaws" for the chuck can help for square cut blanks.
Beware that Jacobs chucks can fall out, which can be dangerous. For this reason I would be very hesitant to put the drill bit on the headstock side (www.youtube.com/watch?v=8BChWGvqgeM). I also hold the chuck in the tailstock as I advance. I personally prefer to stop the lathe when I retract, I feel this generates less heat.
I know that some guys do not mount the bit in the tailstock, they just insert the bit by hand. I prefer mounting in the tailstock just because I am more comfortable with it and have not seen a need to change.
Lastly, I prefer using standard twist drill bits compared to the brad point, I feel I get less drift. Sometimes the standard jobber length is too short (usually only for "modified styles").
__________________
--Sam
Dehn0045 is offline   Reply With Quote Top
Old 11-15-2018, 12:11 PM   #3 (permalink)
Photos: 4
Default
I don't read the OP to be saying that the drill chuck is on the headstock, I'm assuming he's doing it the conventional way with the drill chuck on the tail stock while the blank is affixed to the headstock and spinning.
He is correct, the drill bit does tend to wobble as the bit engages the blank and can indeed cause an oversized entrance hole. There is also often a bit of play in the tailstock as it is locked against the bed.
My approach (which I certainly didnt come up with on my own, and I think is standard) is to begin by drilling a smaller hole with a dedicated stub bit. I bring the tailstock up to the point where the bit barely touches the blank and lock the tailstock down. I start the lathe and extend the quill of the tailstock until my starter hole is drilled. Withdraw the tailstock and replace the stub bit with the drill bit (the consensus does appear to be that brad points are nice in theory but inferior in practice), bring the tailstock back to engage the original hole, lock down and repeat by extending the quill. The presence of the starter hole reduces the wobble of the larger drill bit.
I usually drill only about 1/2" to 3/4" at a time, removing the drill bit to allow removal of the chips and cooling of the bit. I retract the quill and pull the tailstock back with the lathe off and once cooled, reinsert the drill bit to the depth of the already drilled hole, then turn on the lathe and extend the quill another 1/2 to 3/4". Fully reinserting the bit into the deepening hole keeps each subsequent advance coaxial.
__________________
"In theory, there's no difference between theory and practice. In practice, there is."-Yogi Berra
Shock me is offline   Reply With Quote Top
Advertisement
Old 11-15-2018, 01:13 PM   #4 (permalink)
Photos: 0
Default
I use the Dedicated Pen Blank Drilling Chuck from PSI to hold the blank. I use the Turners Select 1/2" Key Drill Chuck from Craft Supplies USA to hold the drill bit. I lock the blank in first. Then I lock in the drill bit. I slide the tailstock down as close to the blank as possible. From there I turn the lathe on and start drilling. I back out the drill bit after a few turns to clean it out. I turn off my lathe and slide the drill bit/tailstock into the hole until it stops. Then I start my lathe and continue to drill the rest of the blank. I've never experienced wobbles doing it this way.
acmaclaren is offline   Reply With Quote Top
Old 11-15-2018, 02:39 PM   #5 (permalink)
MRDucks2's Avatar
Photos: 0
Initially the Fisch bit worked well for me initially but I ended up having issues the more I used it. Same as you, enlarged entry hole, using the bit in a chuck on the talestock and the blank held in jaws on the head.
Ultimately, I stopped using the Fisch bit and my issues went away.
I am sure some have great success with them but once I found I could get better results with much, much lower cost bits I didnít look back.
__________________
Think deeply, Speak gently
Love much, Laugh alot
Work hard, Give freely
Be kind &
Leave The Rest to God
MRDucks2 is offline   Reply With Quote Top
Old 11-15-2018, 04:23 PM   #6 (permalink)
Charlie_W's Avatar
Photos: 3
Default
Yup, longer bits can wander more and without a starter hole or dimple, the bit is subject to the grain of the blank. It will wander off a hard place in the grain and cut into the softer grain. I too use standard twist bits instead of the brad points.
The Brad point bits may be betteat flat grain drilling applications but is not my favorite for end grain.
If drilling a longer blank, either drill from both ends or drill with standard bit first and then switch to the longer bit to finish the drilling. Note that drilling from both ends works better with a true round blank instead of square.
As stated, tailstock play to the bed can be an issue. Also, when drilling, there can be play in the quill.
I use the point of a Skew and turn a dimple in the end of blanks to start the drill.
__________________
Charlie W.
Charlie_W is offline   Reply With Quote Top
Old 11-15-2018, 05:57 PM   #7 (permalink)
Photos: 7
Default
Thank you everyone for your input! I look forward to trying some of these tips to see if I get better results!
Old 11-15-2018, 07:25 PM   #8 (permalink)
MRDucks2's Avatar
Photos: 0
While I like the length and how quickly the Fisch bit clears, I wonder if how the flutes are cut somehow lessens the overall rigidity of the bit when drilling. Or is it just a length thing?
__________________
Be kind &
Old 11-15-2018, 07:58 PM   #9 (permalink)
Member Liaison
leehljp's Avatar
Photos: 46
Default
I must have grown up with a different experience on drilling holes. I am not a "machinist" but know how to drill holes even in metal without it skating.
1. IF the chuck is in the tail stock, LOCK the tail stock down tight. Put a drill bit in it deep enough so that there is a good bite on the bit, and tighten good. With thumb and forefinger only, hold the bit fairly tight and see if you can wiggle it. If so, there is a problem somewhere mechanical. Look for it.
2. Add the blank to the head stock chuck. Tighten it. With thumb and forefinger, can you wiggle it? If so, then check to see of the blank is square. Work on getting the blank into the chuck and with enough pressure / tightness so that it does not wiggle with moderate pressure.
3. Pull the tailstock up and see if the tip of the bit lines up with the center of end of the blank.
4. Caveat: This does not work with some 300+ lb weight lifters. (Of course, - they can wiggle the whole lathe with their thumb and forefinger.)
5. IN most cases for me, I start drilling with high speed and very light touch feed - metal or wood and find that works on the (my Grizzly & Rikon) lathes too. But I will say that I have had years of experience.
I don't have the most expensive lathes, but it is not much different than a drill press. Learning to tighten, insert the bit deep enough into the chuck, check everything mechanical, lock down to keep things from moving BEFORE drilling is necessary. I have all kinds of bits and don't have a problem with holes getting started (on the lathe) where they need to be - because I tighten and check each part before drilling.
Don't assume that because the bit is in the chuck and is snug and that the tail stock is locked - that they are tight.
__________________
Hank Lee
Good is the enemy of Best
leehljp is offline   Reply With Quote Top
Old 11-15-2018, 09:09 PM   #10 (permalink)
Photos: 0
Default
I use a set of pen jaws to hold the blank in the headstock, and a drill chuck in the tail stock, with generally good success. Assuming the set-up of the lathe is good to start with (do points mounted in both head & tail meet?), the closer the blank is to square or round the more accurate the hole. If not square, then rectangular (sides parallel to each other). If the blank starts with sides that are not parallel, as it spins the center moves. It would also be true if your chuck is not running true or holding the blanks true.
This can be best seen by purposely using an out of square blank, with a pencil mounted in the drill chuck. As the blank in the headstock is hand turned, the pencil will mark a small circle instead of a single point. Wouldn't take much of a wobble in the end of the blank to enlarge the entry hole, then as the drill deepens the effect of the eccentric turning gets less and less, so the far end of the blank is the size it should be.
(i've learned this because my cure heat when stabilizing is usually too high--so i'm pushing juice out and too lazy to true the blanks. After ruining a few nice ones--if i have a blank that has an uneven layer of juice on the outside, i turn it round between centers then drill it. I was going to turn that part off any way--so no point in ruining a piece of wood that has only been created once in all of eternity!!)
Hope that made sense, and helps. Now that i've figured it out for me--my drilling tolerances are much much better.
earl
greenacres2 is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
