pen blank drilling centre vice
Roy Merritt
11a Heather road Blackfield Southampton Hants UK S
I have tried ordering the above item from a UK supplier but he is out of stock and is being forced to oder more then he can afford.So he does not know when he will have any in stock.
I beleave that these items are inported from the U.S.A. Does any one know which company this is and there address or an alternative supplier in the UK or the U.S.A.
Thank you for your help in this matter
Roy
PTsideshow
Macomb County Michigan
There are a number of versions of the drilling vise. Does it close by turning a screw or have a toggle clamp and arm you press down ?
http://www.woodcraft.com/images/Products/151256tmb.jpg
These are the versions sold by
Pen Vises PSI versions
Don't know if either ship International.
I'm sure that some vendor on this forum sells pen vises.
:clown:
Mack C.
Passed Away Sep 29, 2018
Brooklin, ON Canada
Roy
Is this what you are looking for?
Pen Blank Drilling Center Vise at Penn State Industries
In the case you drill pen blanks on the lathe, here's a chuck you may wish to consider!
Dedicated Pen Blank Drilling Chuck at Penn State Industries
Roy Merritt
Drilling Vice
Hi Mark
Sorry for delay in responding have been unwell for dew days. This is exactly what I have been looking for, I have contacted Penn State Industries asking for shipping costs and am awaiting a reply. Thank you for your help in this matter. Will keep you informed of our progress and talk later about pen making as I am new to this trade.
Regards
Roy
Roy Merritt
Center Vice
Woodworking Plans & Tools | Fine Woodworking Project & Supplies at Woodcraft
:clown: Hi
These are not quite what we are looking for but another member has found exactly what we were looking for from Penn State Industries but thanks for your help. Will keep you informed.
Regards
Roy
rich gubbin
leicestershire UK
hi there,
i,d be interested in knowing what PSI quoted you on shipping. i wanted to order 5 diva pens and the bushings and the postage was $38 and 4-6 weeks delivery. needless to say i didnt order.
rgrds rich
ironman123
Central Texas
I don't use a pen vise. I cut 2 blocks of MDF and cut a "V" in each and sandwich my blank between them in my drill press vise.
And Rich, I wanted 5 Diva pens also but haven't ordered them yet.
Ray
johncrane
Melbourne, Victoria, Australia.
If you have a drillpress and a vise you can turn the holding plate up, then bolt the vice to the plate, use bolts that are a good fit in the slots, use a set square too true up the vice, or you can square up the vise using a drill bit, just mount a drill bit into the drill chuck move the vise around to grip the drill bit, then do up the vice bolts. By using the vice on its side it will let you drill any size blank for any kit, and it will have a good straight firm grip, also good for longer blanks and easy to clear the sawdust.
