crokett
I also asked this on PSI's website.
the pen kit is the slimline pro click pit - PKPENXXCH
intstructions are here:
https://www.pennstateind.com/library/PK-PENXX_ins.pdf
The diagram makes it seem like the 3-part mechanism is inserted into the upper end of the upper barrel. However the instructions appear to be to insert the mechanism into the lower end of the upper barrel, since you hare supposed to use the lower barrel to push the mechanism further into the upper barrel. I followed the directions but it seemed like the mechanism was too far into the uppper barrel for the button to reach it. I'm hoping someone has assembled this pen knows what the correct sequence is.
• Insert the 3 part plastic mechanism (follow diagram) narrow diameter of the sleeve in first (threaded stub
pointing upward) push in until flush with the edge. Slide the lower barrel with the center band longer
extension into the upper barrel pushing the mechanism sleeve further inside. Continue by pressing the
remaining extension inside.
