Fish30114
I was prepping a blank, cut to length, drilled fine, and brass tube glued in well. I wasn't paying close enough attention, and I didn't measure even after I suspected I fouled up (mistake #2) but I ran the barrel trimmer into the brass tube about 1/8". Soooo....I've got the pen assembled and the refill protrudes about 1/16-1/32 to far, won't fully retract into pen.
What I am looking for help on is, whether or not someone has a tip on how to cure this issue, I was wondering if I could simply drill out a small amount at a time of the plastic insert in the transmission, such that the tip will retract into the body of the pen enough to be acceptable. This is a for sale pen, so I need for this to be a permanent fix, I am not going to put into personal use stock, or I would just trim down the refill A tad bit.
Any info input is appreciated--Thanks--Don
