Herb G
I realize a lot of people back or reverse paint their acrylic blanks and/or tubes so the brass tube won't shine thru. How many of you oversize the drill bit to accommodate the thickness of the paint and/or the epoxy glue?
If so, how much larger do you go? Is 1/2 MM enough to allow for the paint or glue?
For example, a Slimline pen uses a 7 MM drill bit. Would a 7.5 MM drill bit be enough to allow for the thickness of the paint & glue, so it doesn't scrape off when inserting the tube into the blank?
Thanks for any experiences, tips, or tricks.
