If the pen is a Baron, you have an extra coupler, so just grab the existing one with a pair of pliers and pull it out. Fanger once told me his method of taking apart a closed end pen, but it does require some delicacy. First, remove the finial cap. Then figure out what is the largest diameter wood dowel that you can insert into the coupler. With the nib off, good idea, replace the cap and insert the dowel through the cap and coupler until it is again the end of the closed end. I think it works best if the dowel doesn't protrude more than about an inch above the cap. Get a good grip on the cap and hit the dowel with a hammer. Assuming the CB is a good tight fit and the coupler is not an overly tight fit, the closed barrel should come off. The first time I tried this, I made the mistake of using a metal rod and poked a hole through the end., thus finding another way to make a "not closed end" pen.
