William Young
I turned my first olive wood blanks and I dont know if it is spalted or if the dark streaks are just natural coloring of that wood. It looks very similar in appearance to different species of spalted wood. Just in case it was actually spalted and possibly weakened by the spalting process, I drilled the holes and then put some thin CA inside and distributed it with a Q-tip before I glued the tubes in. I didn't want to have a blow out when it got turned thin.
It turned beautifully with long curly shavings coming off both the gouge and the skew.
So my question is,.. .. are the characteristics I have encounterd with this piece normal for olive wood or would it be that the softness of it and the streaky grain pattern with black lines etc. are indeed signs of a spalted piece.
I have not finished it yet because I want to try out a WB high gloss laquer finish on it when it arrives. Hopefully tomorrow.
W.Y.
W.Y.
