ThinkBlot
Last week I ordered some new supplies for a few pen kits. I am making a Roman Harvest, and ordered one of the Olympian Elite kits from PSI that includes the appropriate brad point bits required (which are the same for both kits; 31/64" and 33/64").
I got out a few of my blanks (a bloodwood and a zebrawood) sectioned them, and drilled the 33/64" hole. Both turned out too large. There's about an extra 1/32" of an inch the whole way around the brass tube insert, yielding ruined blanks.
I mounted up a scrap piece of pine and drilled it. The bushing fits perfectly. Bizarre. Tried a piece of bubinga. Hole is too big. Tried to remount the drill bit once again. Still too big. Tried a different drill press. Too big. No matter what I try, the hole is always too big in any of my blanks, but in some soft scrap pine, it is fine.
Unfortunately I don't have a second 33/64" bit around here to try. I did mount up a 1/2" bit, and tried again with some of the previous materials, and the 1/2" bit was right on... and too small for the brass tube. However, if I drill the entire blank with the 1/2" bit, and then remount the 33/64" bit, and try to redrill through the hole I made with the 1/2" bit, then the brass fits fine.
I am so confused! Has anyone ever experienced anything like this?! The only thing I could possibly think of, is if the 33/64" bit is flexing a little bit under the force against the point/flank face?! (but only on woods harder than pine). I am drilling at a slow pace, with frequent pull-outs to dispense the shavings. The wood seems to be cutting easily with no rubbing, heating up or burning. The bit is a PSI HSS brad point bit.
Any ideas? Better yet, know how to fix it? Or am I doomed to requiring a new bit? I certainly can't double drill all my blanks... too easy to get off center and weaken the blank. Thanks in advance!
