Marc Phillips
My new dead and live center finally arrived....
So, off I go to try it out.
<h3>The good news...</h3>
Worked real well... truthfully, never saw one of my blanks spin so smoothly, and I found that I like working on one blank at a time.
<h3>Not so good news, but workable later on...</h3>
Couldn't get my tool rest in close enough... gotta change that for sure..
Dust collector couldn't get in there either... gotta change that too...
<h3>Bad news</h3>
The blank was spinning so great... then it wasn't... not sure what happened, but it developed a bad wobble, and by then there was not enough wood left to turn it again to straighten it out...
I'm confused now... since the bushings were still spinning perfectly smooth... no vibration at all... but the blank got worse and worse.
I could use some help.... I am sure I did something, like tightened the tailstock up too tight or applied too much pressure when sanding or something.... I did try repositioning the blank, and even reversing it on the lathe, but it still wobbled the same. Looking at the end of the blank it looks thicker on one side than the other too....
<h3>Bad news</h3>
