hazard
I made some stupid mistakes with the pens this weekend.
On Friday I was making acrylic blanks for 10 father sing pens from csusa. I went with this pen because they are thicker because I thought I could get away without painting the tubes. Well I drilled and glued the tubes. I went to setup the 1st blank on the mandrel and I didn't realize the bushings on the end were the same as the slimline and 7/16. I realized right of way I was going to have problems seeing the tubes. I turned a purple swirl blank down hoping that it was dark enough to not see the tube. I got a 1/16 from the bushing and I could start to see gold. I then decided to see if I could drill the tube out. Turns out I can without little damage to the acrylic. Now I have to drill the rest out. This also meant I placed an order for more tubes and epoxy.
On Sat/Sun I decided to start making some cigar pens from csusa. These are my first cigar pens. I drilled/glued/turned 5 blanks on Saturday. I then finished them on Sunday. I went to put them together and realized that I totally botched the placement of the bushings. I setup all 5 the same way. They will make good displays or something.
I guess lessoned learned. Maybe I should read the directions. Hopefully I don't do it again.
Chris
Chris
