Non wood blanks
Don Wade
Hawkins, Texas
I am looking for advice regarding chipping out or blowing out of cast blanks when squaring the blanks. ANY ADVICE WOULD BE APPRECIATED.
DurocShark
Anaheim, CA
You talking about using a barrel trimmer? Sharpen it and go more slowly.
There's something in the library (I think that's where it was) on sharpening barrel trimmers. Makes a world of difference.
DurocShark
Anaheim, CA
Is it best? Depends. I use one a lot. But I also use a sanding mill for a lot of things.
I generally chuck my barrel trimmer up in a MT2 drill chuck and stick it in the lathe. Set it to low and trim a bunch of blanks at once. The sander I use by hand to clean up CA glue, or clean up any roughness from the barrel trimmer.
Dave Turner
Sylvania, Ohio
I first learned using a barrel trimmer. A hand drill or drill press worked OK. Downside was having to buy or make the correct sized sleeve to fit inside the brass tube.
I had better results by first turning the blank round to about 3/4". I then could chuck the blank on my lathe and drill a centered hole for the brass tube using a Jacobs chuck on the tailstock. For squaring the blank ends after the tube was glued-in, I would re-chuck the blank in my lathe and now use the barrel trimmer mounted in the Jacobs chuck on the tailstock. Since the barrel trimmer is held centered on the brass tube, there is no need for a sleeve. I still had a problem with the finish on the milled end. Since we are dealing with end grain, it would often be less than smooth. I also experienced some chipping with laminated blanks (Dymondwood).
I ultimately went to using a disc sander with its support table and miter gauge to keep the blank square to the sanding disc. I find this to give me a better finished surface and is faster than using the barrel trimmer. I no longer round my blanks first, but am able to quickly sand off the sharp edges on the sander (for my Tru-stone and acrylic blanks). My shop vac provides excellent dust control. I find my disc sander to be one of my best 50$ investments from Harbor Freight.
Padre
I use a barrel trimmer on all my blanks. Square, round, wood, resin. As long as it is sharp, it will work just fine.
