pinscar
Non-round pen fix.
Here is the first of two real basic questions in two separate threads so others with the same question but unwilling to admit they need help. When I turn my pens, they come out "oblong" i.e. not perfectly round; it is very obvious when I role it across a very flat surface.
I am working with a very hard material with inconsistent density or hardness if you will. I try not to use lots of pressure when I turn and keep my tools as sharp as I can. I use the highest speed when turning. When I get within @1mm of the final diameter, I use CA glue to fill the voids and to "even out" the density or hardness. I am switching to carbide cutters which should hold the sharp edge longer and decrease the temptation to apply more pressure on the blank. I am making a homemade "steady" and I sometimes only turn on the mortise half of the mandrel. I have even sanded when the blank is not turning to even things out.
Any thoughts or ideas?
P.S. I've found a source for new carbide cutters that is very cost effective, however, the cutters are sold in packs of 10. I would like to have 3-4 different sizes and shapes: round, square, triangular, trapezoid, etc., but would rather not spend $200.00 and end up with a lifetime supply of 50 carbide cutters. I would be better off to pay $10.00 to $15.00 each and only get 5. Anyone out there want to split the purchases? Call it $4.00 each plus shipping. Email me at capantler@bellsouth.net.
