I have been reading about No Mandrel tuning for a while - I think I get it but have a few questions - what material(s) is the bushing made from - if hard stell won't it do a number on the tools? If soft (brass, aluminum etc) won't sanding chew them up (as bushing's on a mandrel which are replaced often)? The bushings have got to be a lot more expensive?? How do you sand without sanding the diameter of these more expensive bushings away? Also how do you avoud chewing them up with the turning tools? I'm sure there are obviuos and easy answers to these questions - I have been reading quite a bit here and ned some help, please!!
Also how sells the bushings if I decide to get some once I figure it out!!?
