Next step in Lathes? - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 08-08-2017, 11:25 PM   #1 (permalink)
Photos: 0
Default Next step in Lathes?
First...I did a search but came up with nothing...
I purchased a harbor freight lathe about a year ago when I first learned to turn. I'd like to get something a little nicer. Digital RPM screen and variable speed (via a dial). I'm going to get a buffing setup for the HF lathe.
I ONLY turn pens.
What would everyone suggest. 2 answers.... #1 - budget not an issue #2 - $400 max budget.
Thanks guys!
__________________
Thanks,
---Frank---
Mischief1273 is offline   Reply With Quote Top
Old 08-09-2017, 07:10 AM   #2 (permalink)
WriteON's Avatar
Photos: 0
Default
Budget no issue....The Jet 1015VS is perfect....buying a more expensive lathe for pens will not serve you better.
Best bet for under/around $400 is the Turncrafter 10VS. I do not see any other VS lathes in the $400 range.
Good luck, Frank
__________________
Current set up:
a pair of Jet 1015VS
Jet 1221VS
MidAmericaPool Taig professional pool cue repair lathe....that somehow gets involved with pen blanks.
WriteON is offline   Reply With Quote Top
Old 08-09-2017, 07:29 AM   #3 (permalink)
Photos: 2
Default
For answer #1, I would recommend either the Jet 1221vs or the Rikon 70-220 vsr. In either case, wait for Woodcraft or another local dealer to have a sale.
For #2, Rikon makes a mini for around $300, but it's not variable speed. Same thing for Jet, but you'll pay closer to $400.
For pens, I don't change speeds for turning or sanding/finishing. I have the Jet 1221vs and find the variable speed comes in handy when starting to turn a bowl or other item that is out of round and requires a slow speed for the first portion of the turning. Although you say you only want to turn pens, you may find that your interests change over time, so you might want to consider one of the #1 options. You'll probably have your lathe for many years.
Good luck!
jimmyz is offline   Reply With Quote Top
Advertisement
Old 08-09-2017, 07:37 AM   #4 (permalink)
Photos: 60
Default
If the budget is not an issue, I would recommend either the Rikon 7020vs or the Jet 1221vs.
They are both solid machines and have variable speed. You can get the Rikon for 15% off until the 14th of this month at Woodcraft.
The Jet 12221vs has better variable speed control since you can set the belt to one setting and go from 60 rpm to 3600 rpm with the digital speed control. The Rikon forces you to change belt settings to get those speeds.
The Rikon has a 2 1/2 inch throw on the tail stock, while the Jet only has 2 inch.
eharri446 is offline   Reply With Quote Top
Old 08-09-2017, 08:02 AM   #5 (permalink)
WriteON's Avatar
Photos: 0
Default
Is weight/size a factor? I'm finding they range from 75-125lbs. The Rikon is wide at 40"and heavy. Same with the Jet 1221...around 125lbs.
__________________
Current set up:
Jet 1221VS
Old 08-09-2017, 08:42 AM   #6 (permalink)
Photos: 0
Default
Quote:
Weight isn't a factor but I don't want a large lathe. I prefer a table top....maybe 18"
__________________
Thanks,
---Frank---
Old 08-09-2017, 09:09 AM   #7 (permalink)
WriteON's Avatar
Photos: 0
Default
The lathes that members are suggesting are bench tops. Enjoy what ever you purchase. As someone mentioned Woodcraft has 15% of on Rikons. Try to see one. The RikonVS lathe looks like a great lathe that will do everything and more for you. And for less 15% it runs better.
And thumbs up to the Jet 1221VS.
__________________
Current set up:
Jet 1221VS
Old 09-05-2017, 10:31 AM   #8 (permalink)
Spinzwood's Avatar
Photos: 0
Default
Have you considered the Nova Comet II? Amazon Prime has it for $411 right now. I bought one and feel, for pens etc, it is very nice. For larger items like bowls.. it may be a bit underpowered.. I can't say that yet.
Spinzwood is offline   Reply With Quote Top
Old 09-05-2017, 11:10 AM   #9 (permalink)
BeeAMaker's Avatar
Photos: 0
Default
I like the Shop Fox
https://www.amazon.com/Shop-Fox-W183...shop+fox+lathe
__________________
When you speak, you repeat what you already know. When you listen you learn...
Get the Pressure Pot Caddy!
Vertical Casting System
The MakerHive
BeeAMaker is offline   Reply With Quote Top
Old 09-05-2017, 11:31 AM   #10 (permalink)
Woodchipper's Avatar
Photos: 1
Default
I have a Rikon 70-050VS which was replaced by the 70-220VS. I like it and it does everything I need right now- pens and small turnings as ornaments.
__________________
Due to the lack of interest, tomorrow will be cancelled.
Woodchipper is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
