cestmoi
I made a black titanium Newport (Rockler) pen and thought I followed the assembly instructions carefully. The pen looks fine and the cap screws on/off perfectly. However, the instructions say to drop the spring, large end first, into the lower tube then insert the ink cartridge on top of the spring before finally screwing on the tip assembly. Done this way, the ink cartridge pushes down into the tube--because of the spring it's sitting on--when you write. That doesn't seem correct. The ink cartridge shouldn't push in should it? What am I doing wrong?
