New Motor
skiprat
Passed Away Mar 22, 2022
In a Skip in Wales
I'd get one from a Jet dealer. Then you know the mounting, shaft sizes, power etc will be correct. You could probably find a similar motor cheaper, but then you might have to faff around to mount it.
GregMuller
Miller Place, NY, USA.
Jet Motor
Looked on the Jet parts site and they want over $300 for a replacement motor. I didn't pay that much for the saw new. Gonna look around for a cheap new one or a rebuild.
Bobalu
Social Circle, GA
I use this company when I need repair parts --
http://www.ereplacementparts.com/
I checked and they do carry Jet bandsaw parts, but without a model number that was as far as I could go. I know I can get Ridgid parts cheaper here than I can buying direct from Ridgid, but have yet to deal with them on Jet parts.
randyrls
Harrisburg, PA 17112
You want to look closely at the motor. Most will have a plate on them with the information about the motor. Look for the "Frame Type"; this will be something like "56H". There is a whole alphabet soup of numbers but these numbers specify the mounting parameters, speed and shaft size, any keyway, etc. Take the motor to a local motor shop like Grainger, or Tractor Supply. You should be able to find an exact replacement.
What size motor is on the saw... I bought a new motor for my 1014 lathe from Jet and it wasn't anywhere near that price... my lathe is out of warranty or I think they would have replaced it for free.... they've sent me two tailstock spindle bolts and quills for the ones I ruined drilling pepper mills.
GregMuller
1/2 hp single phase 1750 rpm. After talking to jet it may turn out to be a burned out capacitor. took the old one out and it was not holding a charge. It may have been what smoked. Now I need to find a new one online. No eletronic shops around me.
After I bought my new motor (I didn't check the capacitor before I bought), I discovered the switch was messed up... I had already changed the motor when I discovered the switch problem... I'm thinking my problem never was the motor, just the switch... so I now have a spare motor (I think.. haven't checked it yet either).
beck3906
Belton, TX 76513
Not wanting to to steal the thread, but I have a related question.
Can the capacitor cause the motor to run really slow? My Jet 1014 mini-lathe runs like it is in low gear.
I hate looking for a motor if it's a simple fix.
ed4copies
Local Chapter Manager
Racine, WI, USA.
Why test the EASY stuff, first???
Hey Chuck,
Did a very similar thing with my bandsaw. Took the motor off, to a local repair shop. They tested, said it was NOT bad. Came back to my shop, direct wired the motor--VOILA!!! Now running on a 6 outlet strip with an "off-on" switch. Works great!!
Spec Grade
Maryland
Okay, maybe a dumb question, but where would I look for the capacitor? Is it under the cover on the side of the motor?
Yep. Make sure you use an insulated handled screwdriver & touch it to both terminals to short it out before working on it.
Unplug it from the wall first.
