chiefgreen
Can't find an "un-penturning" forum, so I picked this one. :biggrin:
My question is the dis-assembly of the Slim-Line tip and twist mechanism . I figure removing the twist mechanism before removing the tip is where you start, since trying to remove the tip will probably ruin it.
I thought I had a good idea, after removing the refill, I put a 4" 10-32 screw into the twist mechanism. I pulled on the screw and the twist mechanism came right out, then I was able to remove the tip. Man, am I smart, NOT!. I tried 3 more pens and each time the "guts" of the mechanism came out.
So, what am I doing wrong? Does the tip come off first and if so, how without ruining it? Or, what is the best and most non-destructive way of removing the twist mechanism?
Thanks in advance for the help!
