Need some quick help/advice
Monty
Group Buy Coordinator
Pearland, Texas, USA.
You may remember the Jt Gent II mesquite turquoise inlay pen I posted a few days ago. Well, I just noticed a flaw. There is a gap between the upper barrel and the CB. Looks like I didn't get a good fit between them, as there is a gap of about 1mm that I didn't get the excess CA removed after I finished it. What is the best way to remove/knockout the CB coupling without damaging the plastic guide insert?
Got to do something this weekend as LOML just showed it at work and sold it.
alamocdc
San Antonio, Texas, USA.
Mannie, I've used the transfer punches (HF set w/20 or more punches) to drive out the CB coupling in Barons, Jr. Gents and even Gents and it didn't do any damage (significant, anyway).
Monty
Billy, That's what I planned on doing. Just afraid it would damage the insert. Glad to hear it didn't do any significant damage when you did it.
JimGo
North Wales, PA
Mannie,
The only thing to be careful about is knocking the metallic "cabicon" off the top of the Jr. Gent. You might consider creating a bevel in the bottom of, or drilling a small hole in, the transfer punch.
alamocdc
Mannie, Jim is right. I forgot about that. Yep, it happened with the first one I disassembled. Thankfully, I was able to press it back in. It is one of my daily carriers and is still secure.
mrcook4570
Mason, WV, USA.
I use the transfer punch backwards - Flat end in the tube and hammer the point. Spreads the force over a larger area and keeps the cabachon from flying out.
