airrat
Most of you know I have been playing around with sandstone.
Cutting a blank to size was the first challange, still getting that worked out. Squaring up the ends, need to replace the sand paper on the disk now. It was getting worn anyway.
I drilled up a slimline, glued in the tube with CA. Up to this point not too bad.
I bought some files to help me cut it down. They are not holding up very well. Also I found out the sandstone soaked up some of the CA glue and had a bare spot inside. Next time I will try a different method with the CA or a different glue.
Here is the question, what tools or files are there that sandstone will not destroy. I bought some files and needless to say they would not last through very many pens. AS well as they did not cut it down very fast.
I ended getting a tear out at the end. I tried to glue some dust back in there and found out that CA was not good on the outside. So no CA finish. I cut out the chipped section and will try to think of something later as a oops band.
No pictures tonight, I taped off 1/2 of it and put a couple coats of lacquer on it to see what that does.
Again any ideas on types of files or tools that would stand up to the sandstone.
