lago
I have several cartridge pens where I had a problem when inserting the transmission. Occassionally, it takes more pressure than usual to get the tranny to slide in and when it does go, it sometimes goes in further than I need it. As a result, the tip of the refill sticks out too far. With the method that I use to make the lower, there is not glue or anything that should cause the tranny to bind.
I tried putting a small amount of lithium grease in the barrel and it slide in easy but when completed, it almost turns too easy. Not sure that was a good idea.
Now I am looking for suggestions on how to remove the tranny without destroying the cartridge. Also, do any of you have the same problem when inserting the transmission. FWIW, the transmissions are from WoodNWhimsies.
Lago
Lago
