NEED IDEAS FOR A CLIPLESS SIERRA
altaciii
corpus christi, texas, USA.
I have a returning collector that has ordered 7 sierras, 4 of which are to be clipless. After studing and destroying the finial and clip component on one kit I have determined that it cannot be removed without major damage to the piece. So, plan B, is there any other finial that will fit the turned pieces I already have but will not take away from the total look of the pen?
IPD_Mr
Zionsville, In
Alex take a look at the LeRoi that Smitty has. Same basic design, twist at the top finial and the clip is seperate.
desertrat
Pahrump Nevada
The finial can be disassembled if you apply heat with a heat gun before punching the end cap out. I have done several this way in order to change the clip.
Good luck
John H
Smitty37
Passed Away Mar 29, 2018
Milford, Delaware 19963
Gatsby or Le Roi
The Gatsby from PSI and the Le Roi have pretty much the outward appearance of a Sierra but use different internals and the clip is separate. They are finial twist rather than barrel twist kits. They also do not have the "falling apart" problem that some sierra's exhibit and they don't suffer from getting the transmission crushed due to mishandling either.
