triw51
I assembled a southwest pen from PSI and when I went to insert the ink cartridge it would not fit past the mechanism coupler. Upon inspection I noticed the coupler was bent oval. I tried to correct the problem but still can not screw on the transmission. I contacted PSI and they are sending me a new part.
My question is how to remove the damaged part. The tip coupler is already pressed in, so can not use my transfer punches to push it out. I really want to save the blank as it is cholla cactus I filled the holes with espresso grounds and CA.
