Navigator Disassembly
RetiredJake
Tucson, AZ
Can the Navigator rollerball from Woodcraft be disassembled without damaging the parts?
I need to take it apart to rework the finish.
I have a set of HF transfer punches, but need to know the sequence if it can be done.
TIA
Jake
KenV
Juneau, Alaska.
Navigator = Baron = Sedona for parts and fit
Yes -- if you have a set of transfer punches it is pretty straight forward. You may need to use some thread locking compound (loctite or similar) when reassembly time comes.
Cap -- knock the end out then the coupler.
Remove all the loose pieces. Take out the nib coupler then the center coupler
RetiredJake
Tucson, AZ
Thanks for the response, I'll give it a shot this evening.
Jake
RetiredJake
Tucson, AZ
Got it
Got it apart with no apparent damage, repaired the finish and reassembled.
I now understand the pliers with the rubber jaws to hold a pen during disassembly, my hands still sting
randyrls
Harrisburg, PA 17112
I've done this on occasion, and I use a piece of foam padding. Many gentle hits are preferred to hit strong hits. Hold the pieces over a soft "landing zone".
