bitshird
I finally got a 13.3 MM drill bit, to make a few Churchill's I had laying around then I started looking for something to turn, Well I had cut up some vine a few days ago, my band saw sucks, so I started turning down this 2"x 6" chunk of vine, I got it turned down to about an inch then drilled it, found a few worm tracks a few small pin holes and some wild grain, got the tubes in so now wait until tomorrow morning to finish turning them, I have to figure out a way of squaring some of this stuff up so I can soak it in PR, some is so checked it's nearly in two pieces, and some has several wide checks crossing each other, this will make some striking worthless wood blanks, I was surprised at the density of the vine, it's about as hard as cedar, maybe a bit harder but more porous, I'll post a picture tomorrow when I get it turned.
