Mother of Pearl Blanks - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 05-10-2018, 09:27 PM   #1 (permalink)
Photos: 1
Default Mother of Pearl Blanks
Yesterday I turned my first mother-of-pearl blank. It was a challenge because the material was very fragile and tended to chip easily. I worked slow, took small passes and was able to finish turning and sanding the blank. Then disaster struck when I went to assemble the pen. A small crack appeared on the inside of the blank (not on the exterior). The farther I pushed the transmission in, the longer the crack grew. I had used a chamfering tool prior to assembly on both ends of the blank. Anyone have any suggestions on what else I may try to prevent this in the future? Appreciate your advice.
Seven
__________________
Over the years I have learned that there are only three types of people in this world....those who can count and those who can't.
studioseven is offline   Reply With Quote Top
Old 05-10-2018, 09:57 PM   #2 (permalink)
magpens's Avatar
Photos: 75
Default
Ream out the brass tube so that it slides onto the hardware fairly easily and glue.
I use straight-sided adjustable reamers for this ... available from Grizzly and/or HF.
__________________
Mal
Kids rule the world !!! .... eventually if not already !
magpens is offline   Reply With Quote Top
Old 05-11-2018, 08:39 AM   #3 (permalink)
Photos: 149
Default
Where did you get the blank? Do you have pictures?
__________________
Ron
Pens by Ron
http://www.pensbyron.com
brownsfn2 is offline   Reply With Quote Top
Advertisement
Old 05-11-2018, 08:41 AM   #4 (permalink)
Photos: 1
Default
The blank was a mother-of-pearl from PSI. It was a 7mm size. I will try and get a picture of it.
Seven
__________________
Old 05-11-2018, 08:57 AM   #5 (permalink)
Photos: 149
Default
Oh I see. I have seen those blanks. Those are the mass produced ones. They do tend to be a bit more brittle due to the process they follow. It was the same with the old circuit board blanks they sold. Mass produced PR blanks like that just tend to not turn as well.
__________________
Ron
Pens by Ron
Old 05-11-2018, 09:42 AM   #6 (permalink)
Photos: 0
Default
Mal I have this trouble from time to time as well. I looked up reamers at Grizzly and saw they have a set of adjustable ones. Is that what your using or do you have a one size does it all? Thanks
Kenny Durrant is offline   Reply With Quote Top
Old 05-11-2018, 12:05 PM   #7 (permalink)
Photos: 1
Default
I also looked up the reamers. The smallest I could find is a 1/4". Will that fit inside a 7mm tube?
Seven
__________________
Old 05-11-2018, 01:44 PM   #8 (permalink)
Photos: 1
Default
Quote:
Seven
A quick search would tell you the answer is yes. 7mm = 0.2756" and 1/4" = 0.250".
__________________
Pete
Proud to be the support staff and enabler of Marla Christensen.
Curly is offline   Reply With Quote Top
Old 05-11-2018, 01:51 PM   #9 (permalink)
Photos: 1
Default
7mm is the outside diameter. What is the inside diameter?
__________________
Old 05-11-2018, 02:56 PM   #10 (permalink)
Photos: 1
Default
Whoops. Walls are generally about 0.014 thick so that would make the inside of the tube close to 0.245". So it might not fit. I did find a number of 6.0 to 6.5mm adjustable reamers on Ebay for about $10.00Can/$8.00US that should do the trick if the 1/4" was too big to start. Or you could get the 6.5mm-7mm if you didn't want the imperial set. Or a metric set though aliexpress.
https://www.ebay.ca/sch/i.html?_from...amers&_sacat=0
https://www.ebay.ca/sch/i.html?_odkw...amers&_sacat=0
https://www.aliexpress.com/item/The-...ceBeautifyAB=0
https://www.aliexpress.com/item/9pcs...ceBeautifyAB=0
__________________
Pete
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
