GregD
With so many pen kits available, what are the most common drill bits used? 7mm 8mm 10mm and ?????????????
Originally posted by woodscavenger
<br />Where do you find a cheap 17/32 for the Gentlemans pen...?
Originally posted by GregD
<br />Just a suggestion, once you have found the center, center punch it.The bit will follow into the small hole created by the punch and not walk off to one side or the other.
Originally posted by DCBluesman
<br />The only tricks I know of are a steady drilling jig of your choice and a truly square drill press table. Go slow, nibbling your way through. I've made several Barons, which use the 15/32" bit out of 5/8" blanks, but I hold my breath a bit.
