More finishing? - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 01-07-2019, 10:04 AM   #1 (permalink)
Woodchipper's Avatar
Photos: 1
Default More finishing?
I had talked about some problems with a pen mill. Another question arises about finishing. Both blanks have CA on them and the CA came out very good, IMHO. However, I wonder about going a step farther with MM. Your advice is most welcome. TIA. Will wait for your replies before final assembly.
An aside to go along with finishing- the purpleheart blank has a thin, dark ring at the ends of the blank. What causes this? Thanks, again.
__________________
To err is human; To really mess it up, you need a computer.
Woodchipper is offline   Reply With Quote Top
Old 01-07-2019, 11:00 AM   #2 (permalink)
Chief TomaToe's Avatar
Photos: 0
Default
What made the biggest difference for me and my CA finish was adding a buffing stage after the MM step. There are multiple places you can get a buffing kit that uses the blue compound that are very inexpensive. I'm sure there are better systems, but it works just fine for me. When I first started, I would end up having very fine cylindrical scratches around the pen even when I used a plastic polish. Just to try it, I bought a buffing kit for my lathe and, wouldn't you know, it worked! I have learned that a final buffing stage will not fix a bad MM job, but it will get rid of all those tiny scratches that prevent a CA finish going from good to perfect.
Chief TomaToe is offline   Reply With Quote Top
Old 01-07-2019, 11:33 AM   #3 (permalink)
Member Liaison
leehljp's Avatar
Photos: 46
Default
Dark ring at the end of the blank: You are using bushings and sanding the bushings. The bushing dust makes the black ring. Preventing the black rings can be done two ways:
1. Refine sanding techniques; move from the center of the blank outward; Learn to sand without touching the bushings;
Or
2. Remove the bushings before sanding. Bring to size by measuring the blank with calipers instead of using the bushings to size it.
Think of it this way; after 10 to 20 blanks turned and sanded to size on a given set of bushings, the bushing will have been reduced in size by about .01. The bushing keeps shrinking in size the more you turn with it and sand with it on the mandrel.
__________________
Hank Lee
Good is the enemy of Best
leehljp is offline   Reply With Quote Top
Advertisement
Old 01-07-2019, 01:15 PM   #4 (permalink)
Photos: 1
Default
Thanks, Chief. Will look at the lathe polishing setup. Woodcraft is my go-to place.
Lee, I'll look into eliminating the bushings, either by learning to TBC or put a nylon or plastic spacer between the blank and the bushing before sanding.
If I sand my waistline, will that shrink it to a small diameter?
__________________
Old 01-07-2019, 02:25 PM   #5 (permalink)
Photos: 1
Default
If you used a pen mill on the purpleheart it likely "cooked" the wood and turned it darker.
Whenever I make purpleheart pens I turn it down to the final size and then cook it in an old toaster oven at 400 degrees for about 10-12 minutes. It will darken it to a deep purple. This will likely vary with different pieces and thickness of wood so you would want to watch it closely to get it the way you like.
If you've already put CA on it, it's probably too late to heat it up. Unless you sand off the CA first.
BCnabe is offline   Reply With Quote Top
Old 01-07-2019, 04:10 PM   #6 (permalink)
Photos: 1
Default
The end turned black. I quit using the pen mill and sanded it on the lathe. Actually I got pretty accurate with the PH and the ebony. Assembled the pens and will take some photos. I will take some extra wood (got tons of it) and practice turning with a skew and Lee's suggestions on turning and sanding. I have calipers- will measure the diameter of the components and the length of the tube. Always a learning experience.
BTW, I found a nice lathe. Anyone got an extra $7,000 laying around gathering dust?
__________________
Old 01-07-2019, 04:22 PM   #7 (permalink)
sbwertz's Avatar
Photos: 42
Default
I keep my pen mills really sharp with a diamond card, and use the drill press to mill blanks. We go through dozens of blanks every week, and are often milling 20 or more blanks at a time. I hold the blank with a pair of water pump pliers and mill a bit, check for brass, mill a bit until i just barely see brass. For really hard wood, I turn almost to size, take it off the lathe and mill it, then finish turning it so it doesn't overheat. But I sharpen those puppies every week. I have two mills, and keep one set up with 7mm, and have different centers for different sized pens that i put in the other one. For those sizes I don't have, I turn sleeves on a 7mm brass tube and label them with the size and/or pen kit name.
Our lathes are kept busy all the time, so it isn't convenient to try to mill using the lathe. I can't afford to give up the turning time.
__________________
Sharon in Phoenix
sbwertz is offline   Reply With Quote Top
Old 01-07-2019, 06:08 PM   #8 (permalink)
Photos: 1
Default
I tried a DMT diamond file but didn't get the results I wanted. Don't think I got the proper angle and didn't remove much metal to make a difference.
I'm going to make stand to hold my "Dremel" tool and use a stone to see if that will work. Will report with my results.
__________________
Old 01-07-2019, 07:16 PM   #9 (permalink)
Photos: 0
Default
Another option for sanding is to turn wooden pen bodies on bushings, reinstall the pen bodies on the mandrel with non stick tapered bushings, and sand. I start with 240 grit but stay away from the last 1/8" of the pen bodies until I move up to 320, so that I don't significantly reduce the diameter at the ends of the pen bodies.
donstephan is offline   Reply With Quote Top
Old 01-09-2019, 08:25 AM   #10 (permalink)
Photos: 1
Default
Don, good idea. Used to live in Cincy; miss Skyline chili!
__________________
Related Content
Reply
Bookmarks
Tags
ca glue , micro mesh
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
