EasyGreasy
I have about a hundred or so pens done with my micromesh. I think its lost alot of its sanding ability. Someone said that this stuff lasts forever but.. I have sanded brass and aluminum lots of hardwood pens and plastics. The upper grits look smooth and have probably melted or just worn down. I am not so much the rookie anymore and I realize that the damage was probably done early when I would put alot of pressure on the pad. The brass and aluminum probably didnt help since it heats up fast.
Who has a good deal on MicroMesh. I promise I will use a light touch, do the plastics with water, clean it after each use and not burn it by holding it in one place for too long. And not let the dog chew on the 1500 grit again.
Any good deals on MicroMesh and any advise on dos and donts would be helpfull. Though I have allready found alot of donts. Thanks
Greasy
Greasy
