Method of sealing brass tubes
GaWoodworker
When I cast resin pens, I generally use clay or wax but sometimes i get leaks that create bubbles in the resin. What methods have you folks used that is effective for blocking resin out of the pen tubes?
Ron Mc
USA.
I can't help you with your question but and can tell you that you have one of the ugliest dogs I have ever seen!
Gary Max
Southern Kentucky
If I am reading your post right-------that's a easy one.
BB sells beeswax in thin sheets that is made for this.
His web site is list on IAP's home page---Arizona Silhouette
Hope this is what you are looking for
GaWoodworker
Originally posted by Ron Mc
<br />I can't help you with your question but and can tell you that you have one of the ugliest dogs I have ever seen!
What?! Fee-fee is such a sweet cuddly doggy[B)]
GaWoodworker
Originally posted by Gary Max
<br />If I am reading your post right-------that's a easy one.
That does look like what I am looking for! Have you tried this wax with pressure casting? I am wondering if the pressure would cause it to move since the air behind it might be compressed under 50-60 psi?[?]
Romania.
Hi 2 all! and Happy New Turnings!
U could try the potato trick like in : Turning Pens And Pencils (by Kip Christensen, Rex Burningham).
Basically cut fresh potato into 1/4" thick sheets, press the end of the tube until it cuts the potato. Makes a great non sticky, easy 2 clean cap 4 tubes.
